Configure CFM MEP
Use this procedure to configure the CFM Maintenance Endpoint (MEP). A MEP represents a managed CFM entity, associated with a specific Domain Service Access Point (DoSAP) of a service instance, which can generate and receive CFM Protocol Data Units (PDU) and track any responses. A MEP is created by MEP ID under the context of an MA.
 - Click CFM.
 - Click the MD tab.
 - Highlight an existing MD, and then click MaintenanceAssociation.
 - In the MA tab, highlight an existing MA, and then click MaintenanceEndpoint.
 - Click Insert.
 - In the fields provided, specify the ID and the administrative state of the MEP.
 - Click Insert.
MEP Field Descriptions
Use the data in the following table to use the MEP tab.
 Name  |
 Description  |
 DomainIndex  |
 Specifies the MD index.  |
 AssociationIndex  |
 Specifies the MA index.  |
 Id  |
 Specifies the MEP ID.  |
 DomainName  |
 Specifies the MD name.  |
 AssociationName  |
 Specifies the MA name.  |
 AdminState  |
 Specifies the administrative state of the MEP. The default is disable.  |
 MepType  |
 Specifies the MEP type:
 ServiceDescription  |
 Specifies the service to which this MEP is assigned.  |
