Configure Layer 2 Ping
Use this procedure to configure a Layer 2 ping inside an SPBM cloud or network. This feature enables CFM to debug Layer 2. It can also help you debug IP shortcuts and the record for the shortcuts‘ ARP.
On the source and destination nodes, you must configure a CFM MD, MA, and MEP, and assign a nodal MEP to the B-VLAN.
 - Click L2Ping/L2Trace Route.
 - From the L2Ping tab, configure the Layer 2 ping properties.
 - To initiate a Layer 2 ping, highlight an entry and click the Start button.
 - To update a Layer 2 ping, click the Refresh button.
 - To stop the Layer 2 ping, click the Stop button.
L2Ping Field Descriptions
Use the data in the following table to use the L2Ping tab.
 Name  |
 Description  |
 VlanId  |
 Identifies the backbone VLAN.  |
 DestMacAddress  |
 Specifies the target MAC address.  |
 HostName  |
 Specifies the target host name.  |
 DestIsHostName  |
 Indicates whether the host name is (true) or is not (false) used for L2Ping transmission.  |
 Messages  |
 Specifies the number of L2Ping messages to be transmitted. The default is 1.  |
 Status  |
 Specifies the status of the transmit loopback service:
 This field is also used to avoid concurrency or race condition problems that can occur if two or more management entities try to use the service at the same time. The default is ready.  |
 ResultOk  |
 Indicates the result of the operation:
 The default is true.  |
 Priority  |
 Specifies a 3–bit value to be used in the VLAN header, if present in the transmitted frame. The default is 7.  |
 TimeoutInt  |
 Specifies the interval to wait for an L2Ping time-out. The default value is 3 seconds.  |
 TestPattern  |
 Specifies the test pattern to use in the L2Ping PDU:
 A cyclic redundancy check is a code that detects errors. The default value is allZero.  |
 DataSize  |
 Specifies an arbitrary amount of data to be included in the data TLV, if the data size is selected to be sent. The default is 0.  |
 FrameSize  |
 Specifies the frame size. If the frame size is specified then the data size is internally calculated and the calculated data size is included in the data TLV. The default is 0.  |
 SourceMode  |
 Specifies the source mode of the transmit loopback service:
 The default is nodal.  |
 SeqNumber  |
 The transaction identifier/sequence number of the first loopback message (to be) sent. The default is 0.  |
 Result  |
 Displays the Layer 2 Ping result.  |
