Configure the SNMP table of filter profiles to determine whether particular management targets receive particular notifications.
 - Click Notify Table.
 - Click the Notify Filter Table tab.
 - Click Insert.
 - In the NotifyFilterProfileName box, type a name for the notify filter profile.
 - In the Subtree box, type subtree location information in x.x.x.x.x.x.x.x.x.x. format.
 - In the Mask box, type the mask location in hex string format.
 - From the Type options, select included or excluded.
 - Click Insert.
Notify Filter Table Field Descriptions
Use the data in the following table to use the Notify Filter Table tab.
 Name  |
 Description  |
 NotifyFilterProfileName  |
 Specifies the name of the filter profile used to generate notifications.  |
 Subtree  |
 Specifies the MIB subtree that, if you combine it with the mask, defines a family of subtrees, which are included in or excluded from the filter profile. For more information, see RFC 2573.  |
 Mask  |
 Specifies the bit mask (in hexadecimal format) that, in combination with the subtree, defines a family of subtrees, which are included in or excluded from the filter profile.  |
 Type  |
 Indicates whether the family of filter subtrees are included in or excluded from a filter. The default is included.  |
