Use the following procedure to verify the proper global SPBM configuration.
Switch# show isis spbm
                                                ISIS SPBM Info
SPBM       B-VID      PRIMARY    NICK     LSDB     IP       IPV6     MULTICAST  SPB-PIM-GW         STP-MULTI
INSTANCE              VLAN       NAME     TRAP                                                     HOMING
1          4051-4052  4051                disable  disable  disable  enable     disable            enable
                                             ISIS SPBM SMLT Info
SPBM       SMLT-SPLIT-BEB       SMLT-VIRTUAL-BMAC     SMLT-PEER-SYSTEM-ID
INSTANCE
1          primary              00:00:00:00:00:00
Total Num of SPBM instances: 1
Switch# show vlan basic
                                   Vlan Basic
VLAN                              INST
ID    NAME             TYPE         ID  PROTOCOLID SUBNETADDR      SUBNETMASK   VRFID
1     Default          byPort       0   none       N/A             N/A		  0
10    VLAN-10          spbm-bvlan   62  none       N/A             N/A		  0
20    VLAN-20          spbm-bvlan   62  none       N/A             N/A		  0
100   VLAN-100         byPort       0   none       N/A             N/A		  0
All 5 out of 5 Total Num of Vlans displayed
