Perform this procedure to view the amount of switch capacity and PoE power being saved on the units.
 - Click Energy Saver.
 - Click the Energy Savings tab.
Energy Savings field descriptions
 Name  |
 Description  |
 UnitIndex  |
 Specifies the unit number.  |
 UnitSavings(1/10 watts)  |
 Specifies the amount of switch capacity power being saved on the specific unit.  |
 PoeSavings(1/10 watts)  |
 Specifies the amount of PoE power being saved on the specific unit.  |
