Perform this procedure to configure VRRP notification control.
Assign an IPv6 address to the interface.
Enable routing globally.
Change the VRF instance as required to configure VRRP notification control on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
 - Click VRRP.
 - Click the Globals tab.
 - Select enabled.
 - Click Apply.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name  | Description  |
NotificationCntrl  | Indicates whether the VRRP-enabled router generates SNMP traps for events.
 The default is enabled.  |
