Use this procedure to assign a nodal MEP to an SPBM B-VLAN. The Nodal MEP provides traceability and troubleshooting at the system level for a given B-VLAN. The Nodal B-VLAN MEPs created on the CP and function as if they are connected to the virtual interface of the given B-VLAN. Because of this they are supported for both port and MLT based B-VLANs.
Nodal MPs provide both MEP and MIP functionality for SPBM deployments. Nodal MPs are associated with a B-VLAN and are VLAN encapsulated packets. Each node (chassis) has a given MAC address and communicates with other nodes. The SPBM instance MAC address is used as the MAC address of the Nodal MP.
You must configure a CFM MD, MA, and MEP.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# vlan nodal-mep 100 md1 ma1 2
Switch:1(config)# show vlan nodal-mep
                                 Vlan Nodal Mep
VLAN_ID    DOMAIN_NAME.ASSOCIATION_NAME.MEP_ID
100       spbm.100.6
200       spbm.200.6
Switch:1(config)# vlan nodal-mip 100 6
Switch:1(config)# show vlan nodal-mip
                              Vlan Nodal Mip Level
VLAN_ID    NODAL_MIP_LEVEL_LIST
1
100		    6
216
304
41000
1001
The following table defines parameters for the vlan nodal-mep command.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID.  |
 WORD<0–22>  |
 The first parameter, specifies the Maintenance Domain name.  |
 WORD<0–22>  |
 The second parameter, specifies the Maintenance Association name.  |
 <1–8191>  |
 Specifies the nodal MEPs to add to the VLAN.  |
The following table defines parameters for the vlan nodal-mip-level command.
 Variable  |
 Value  |
 <1-4059>  |
 Adds the nodal MIP level. Specifies the VLAN ID.  |
 WORD<0–15>  |
 Adds the nodal MIP level, which has up to eight levels, ranging from 0 to 7.  |
