Add a remote NTP server to the configuration by specifying its IP address. NTP adds this IP address to a list of servers, which the local NTP client uses to query remote time servers for time information. The list of qualified servers called to is a peer list.
This procedure is only supported on VSP 8600 Series.
For NTPv3, you can configure a maximum of 10 IPv4 NTP servers.
 - Select NTPv3.
 - Select the Server tab.
 - Select Insert.
 - Specify the IP address of the NTP server.
 - Select Insert.
Server Field Descriptions
Use the data in the following table to use the Server tab.
 Name  |
 Description  |
 ServerAddressType  |
 Specifies the IP address of the remote NTP server.  |
 Enable  |
 Activates or disables the remote NTP server. The default is enabled.  |
 Authentication  |
 Activates or disables MD5 or SHA1 authentication on this NTP server. MD5 or SHA1 produces a message digest of the key. MD5 or SHA1 verifies the integrity of the communication, authenticates the origin, and checks for timeliness. The default is no authentication.  |
 KeyId  |
 Specifies the key ID used to generate the MD5 or SHA1 digest for this NTP server. The default is 0, which indicates that authentication is disabled.  |
 AccessAttempts  |
 Specifies the number of NTP requests sent to this NTP server.  |
 Success  |
 Specifies the number of times this NTP server updated the time.  |
 Failure  |
 Specifies the number of times the client rejected this NTP server while it attempted to update the time.  |
 Stratum  |
 This variable is the stratum of the server.  |
 Version  |
 This variable is the NTP version of the server.  |
 RootDelay  |
 This variable is the root delay of the server.  |
 Precision  |
 This variable is the NTP precision of the server in seconds.  |
 Reachable  |
 This variable is the NTP reachability of the server.  |
 Synchronized  |
 This variable is the status of synchronization with the server.  |
 SourceIpAddr Note:
Exception: only supported on VSP 8600 Series.  |
 Specifies the source IP for the server. If you do not configure a source IP, by default, the entry is initialized to 0.0.0.0. The IP address specified can be any local interface.  |
