                                 Feature  |
                                 Product  |
                                 Release introduced  |
                                 Entity MIB - Physical Table  |
                                 5420 Series  |
                                 VOSS 8.4  |
                                 5520 Series  |
                                 VOSS 8.2.5  |
                                 VSP 4450 Series  |
                                 VOSS 6.0  |
                                 VSP 4900 Series  |
                                 VOSS 8.1  |
                                 VSP 7200 Series  |
                                 VOSS 6.0  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 VOSS 6.0  |
                                 VSP 8400 Series  |
                                 VOSS 6.0  |
                                 VSP 8600 Series  |
                                 VSP 8600 6.1  |
                                 XA1400 Series  |
                                 VOSS 8.0.50  |
                                 Entity MIB enhancements and integration for the following:
                                 5420 Series  |
                                 VOSS 8.4  |
                                 5520 Series  |
                                 VOSS 8.2.5  |
                                 VSP 4450 Series  |
                                 VOSS 6.1.2  |
                                 VSP 4900 Series  |
                                 VOSS 8.1  |
                                 VSP 7200 Series  |
                                 VOSS 6.1.2  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 VOSS 6.1.2  |
                                 VSP 8400 Series  |
                                 VOSS 6.1.2  |
                                 VSP 8600 Series  |
                                 VSP 8600 6.1  |
                                 XA1400 Series  |
                                 VOSS 8.0.50  |
                                 Entity MIB - Logical Table includes the following logical interface entities:
                                 5420 Series  |
                                 VOSS 8.4  |
                                 5520 Series  |
                                 VOSS 8.4  |
                                 VSP 4450 Series  |
                                 VOSS 8.4  |
                                 VSP 4900 Series  |
                                 VOSS 8.4  |
                                 VSP 7200 Series  |
                                 VOSS 8.4  |
                                 VSP 7400 Series  |
                                 VOSS 8.4  |
                                 VSP 8200 Series  |
                                 VOSS 8.4  |
                                 VSP 8400 Series  |
                                 VOSS 8.4  |
                                 VSP 8600 Series  |
                                 Not supported  |
                                 XA1400 Series  |
                                 VOSS 8.4  |
The Entity MIB – Physical Table assists in the discovery of functional components on the switch. The Entity MIB – Physical Table supports a physical interface table that includes information about the chassis, power supply, fan, I/O cards, console, and management port.
Some hardware platforms support removable interface modules while others offer a fixed configuration. The names used for these modules can vary depending on the hardware platform.
The following table identifies the entity index range for the switch components.
                             Component  |
                             Entity index range  |
                             Chassis  |
                             1  |
                             Power supply slot  |
                             3 to 8  |
                             Fan tray and fan slot  |
                             9 to 16  |
                             I/O slot  |
                             17 to 30  |
                             SF Slot  |
                             31 to 36  |
                             I/O card or module  |
                             37 to 50  |
                             SF Card  |
                             51 to 56  |
                             Console port  |
                             57  |
                             Console port 2  |
                             58  |
                             Management port  |
                             64  |
                             Management port 2  |
                             65  |
                             Power supply  |
                             68 to 73  |
                             Fan tray  |
                             74 to 81  |
                             Fan module  |
                             82 to 105  |
                             Port  |
                             192 to 1023  |
                             Pluggable Module and Sensor  |
                             19201 to 102314  |
For more information about Entity MIB – Physical Table, see View Physical Entities.
