This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to configure the onboarding I-SID for ports that are operating in Auto-sense mode. The onboarding I-SID is typically used to onboard networking devices such as switches and non FA capable access points. By default, the onboarding I-SID provides automatic reachability when switches are booted from factory without a configuration file. For security reasons, the onboarding I-SID forms an isolated PVLAN/ETREE to block any unwanted port to port cross talk.
Configuring the Auto-sense onboarding I-SID:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense onboarding i-sid 15000000
The following table defines parameters for the auto-sense onboarding command.
                                 Variable  |
                                 Value  |
                                 i-sid<1-16777215>  |
                                 Specifies the service instance identifier (I-SID). The default onboarding I-SID value is 15999999.  |
