Use the following procedure to configure Fabric Extend (FE) between a Main office to a Branch office. This is a typical deployment. However, if your deployment creates tunnels between two switches that support Fabric Extend natively, then repeat those steps and ignore the steps for switches that require an ONA.
VRF is an optional parameter. If a VRF is not configured, then FE uses the GRT.
The tunnel source IP address can be either a brouter port IP, a CLIP IP, or a VLAN IP.
Product Notice: Except VSP 8600 Series, all product series support a VLAN IP as the Fabric Extend tunnel source IP address.
The tunnel source IP address must be on the GRT, not on a VRF.
A best practice is to use separate IP addresses for the SPBM IP Shortcuts ip-source-address command and the Fabric Extend ip-tunnel-source-address command. However, if you want these IP addresses to be the same, you MUST exclude the ip-source-address address with an IS-IS accept policy. You cannot use the redistribute command with a route map exclusion.
Specify a CLIP interface to use as the source address for SPBM IP shortcuts.
If IP Shortcuts is enabled, you must configure an IS-IS accept policy or exclude route-map to ensure that tunnel destination IP addresses are not learned through IS-IS.
Configure a CLIP and tunnel source IP address on the VRF.
Remote management of the VSP 4450 Series is possible after establishing IP Shortcut over IS-IS. (Alternatively, you can enable GRT-VRF redistribution locally.)
Configuring Fabric Extend consists of two primary tasks: configuring the tunnel source address and configuring the logical interface. These tasks must be completed on both ends of the tunnel.
Note that the VSP 4450 Series source address command is different than other platforms. Also note that the logical interface commands are different between Layer 2 and Layer 3 networks.
The following steps are for platforms that support FE natively:
 - Select IS-IS.
 - Select the Globals tab.
 - In the IpTunnelSourceAddress field, enter the IP tunnel source address.
 - If you are using a VRF, select IpTunnelVrf field.
 - Select Apply.
The following steps are for platforms that require an ONA to support FE:
The interface VLAN connecting to the ONA network port is always in the GRT and the member port that the VLAN is part of is always an access port.
 - Select IS-IS.
 - In the IpTunnelPort field, select the physical port that the logical interface is connected to in an Layer 2 network.
 - If you are using a VRF, select its name from the list for IpTunnelVrf.
 - In the IpTunnelMtu field, enter a value between 750 and 1950 to specify the size of the maximum transmission unit (MTU).
 - Select Apply.
Fabric Extend Field Descriptions
Use the data in the following table to use the Globals tab.
                                                   Name  |
                                                   Description  |
                                                   IpTunnelSourceAddress  |
                                                   Specifies the IS-IS IPv4 tunnel source address.  |
                                                   IpTunnelPort  |
                                                   Specifies the physical port that the logical interface is connected to in an Layer 2 network. The parameter is for the VSP 4450 Series only.  |
                                                   IpTunnelVrf  |
                                                   Specifies the VRF name associated with the IP tunnel.  |
                                                   IpTunnelMtu  |
                                                   Specifies the size of the maximum transmission unit (MTU). The default is 1950. This parameter applies to an ONA configuration only.  |
