Perform this procedure to add ports to an MLT LAG.
Add port 1/24 to MLT 40:
Switch:1(config)# mlt 40 member 1/24
Variable definitions
Use the data in the following table to use the mlt command.
 Variable  |
 Value  |
 enable  |
 Creates and enables a new MLT.  |
 encapsulation dot1q  |
 Enables trunking on the MLT.  |
 member {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Adds ports to the MLT. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 <1-512>  |
 Specifies the MLT ID.  |
 name WORD<0-20>  |
 Configures the name for the MLT.  |
 private-vlan {isolated|promiscuous|trunk}  |
 Specifies a private VLAN type for the MLT.  |
 vlan <1-4059>  |
 Specifies a VLAN ID to add to the MLT.  |
