Use FTP or SFTP to transfer the OVA image to the /var/lib/insight/packages/ directory on the switch.
Perform the following procedure to configure the package information to be used by the virtual service.
 - Select Virtual Service.
 - Select the Application tab.
 - Select Insert.
 - In the Name field, enter the virtual service name.
 - Next to the PackageName field, select the ellipsis, select the package to install, and then select Ok.
 - Select Insert.
Application Field Descriptions
Use data in the following table to use the Application tab.
 Name  |
 Description  |
 Name  |
 Specifies the name of the virtual service.  |
 PackageName  |
 Specifies the name and location of the package.  |
                         InstallResult  |
                         Shows the status of the virtual service installation.  |
                         InstallStage  |
                         Shows the stages of a package installation.  |
                                 PackageAppName  |
                                 Shows the application name used by the virtual service.  |
                                 PackageAppVersion  |
                                 Shows the application version used by the virtual service.  |
