Use this procedure to view IP multicast route statistics.
You must enable the collection of multicast statistics.
- In the navigation pane, expand the following folders: .
 - Click Multicast.
 - Click the Stats tab to view the statistics.
Stats Field Definitions
Use the data in the following table to use the Stats tab.
 Field  |
 Description  |
 GroupAddress  |
 Specifies the multicast group IP address for which to show statistics.  |
 SourceCounter  |
 Specifies the number of sources associated with the multicast route record.  |
 Pkts  |
 Specifies the number of packets received for the associated IP address.  |
 Bytes  |
 Specifies the number of bytes received for the associated IP address.  |
 AverageSizePerPkt  |
 Specifies the average packet length for the associated group IP address. This information indicates only the ingress packet length and is calculated using the following formula: ingress packet/ingress byte.  |
