An observation domain consists of a collection of flow groups. Use this procedure to assign a unique ID to an observation domain. The default value is 0.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix observation-domain 1
Use the data in the following table to use the ip ipfix observation-domain command.
 Variable  |
 Value  |
                             observation-domain <0-4294967295>  |
                             Specifies a value for the observation domain used to send IPFIX messages. The default is 0 (no observation domain). If the value is 0, data that is sent is not applied to a single observation domain.  |
