Use this procedure to configure the global IPv6 PIM-SM parameters on the switch.
Switch:1(config)#show ipv6 pim
                        Pim General Group - GlobalRouter
PimStat               : disabled
Mode                  : sparse
StaticRP              : disabled
FwdCacheTimeout       : 210
DiscDataTimeout       : 60
RegSupprTimeout       : 60
UniRouteChangeTimeout : 5
JoinPruneInt          : 60
The following table describes the variables for the ipv6 pim command.
| Variable | Value |
                             disc-data-timeout <5-65535>  |
                             Specifies the duration in seconds to discard data until the switch receives the join message from the rendezvous point (RP). An IP multicast discard record is created after a register packet is sent, until the timer expires or the switch receives a join message. The default value is 60.  |
                             enable  |
                             Enables PIM globally on the switch. The default is disabled.  |
                             fwd-cache-timeout <10-86400>  |
                             Specifies the forward cache timeout value. The default value is 120.  |
                             join-prune-interval <1-18724>  |
                             Specifies the duration in seconds before the PIM router sends out the next join or prune message to its upstream neighbors. The default value is 60.  |
                             mode <sparse> <ssm>  |
                             Configures PIM mode on the switch. The default value is sparse.  |
                             register-suppression-timeout <10-65535>  |
                             Specifies the duration in seconds the designated router (DR) suppresses sending registers to the RP. The timer starts after the DR receives a register-stop message from the RP. The default value is 60.  |
                             static-rp  |
                             Add new static-rp entries and enable static-rp.  |
                             unicast-route-change-timeout <2-65535>  |
                             Specifies the duration in seconds the switch polls the RTM for unicast routing information updates for PIM. The default value is 5.  |
