Use the following procedure to link an IPsec policy to a management interface,
                        and configure a policy direction. By default, the direction is both.
This procedure applies to VSP 8600 Series only.
You must enable IPsec on the interface first, and then you link the IPsec policy to the interface.
Link the IPsec policy for IPv4 to the management interface:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface mgmtEthernet mgmt Switch:1(config-if)#ip ipsec policy newpolicy dir both
The following table defines parameters for the ip ipsec policy and ipv6 ipsec policy commands.
 Variable  |
 Value  |
 WORD<1–32>  |
 Specifies the policy ID.  |
 dir <both|in|out>  |
 Specifies the direction you want to protect with IPsec:
 The default is both.  |
