Configuring counter polling
Use this procedure to configure counter polling using the EDM.
This tab is not supported on all hardware platforms.
 - Click sFlow.
 - Click the Counter Polling tab.
 - In the Index column, navigate to the slot and port where you want to configure sFlow.
 - Double-click the Interval field and enter a value in seconds.
 - Click Apply.
Counter Polling Field Descriptions
Use the data in the following table to use the Counter Polling tab.
 Name  |
 Description  |
 Index  |
 Identifies the source of the data for counter polling.  |
 Receiver  |
 The sFlow receiver associated with the counter polling.  |
 Interval  |
 The maximum number of seconds between successive samples of the counters associated with this data source. A sampling interval of 0 disables counter sampling.  |
