Use this procedure for the following tasks:
Display the digital certificate for a certificate type or list all the certificate details from the local store.
Display the certificate authority (CA) details for a trustpoint CA name or list all the CA details from the local store if the CA name is not specified.
Display the configured key details for a key name.
Display the configured subject details.
Switch:1>enable Switch:1#virtual-service FIGW console FIGW>show certificates keys key_rsa Key Label: key_rsa private key with: pubkey: RSA 2048 bits keyid: ef:4c:1d:a7:cc:84:6f:87:da:e4:de:99:07:3d:96:fc:9a:d1:c9:f4 subjkey: cb:d1:67:a0:da:9c:05:ce:c0:0d:a3:5c:1b:ba:ce:3f:ff:af:8f:77
The following table defines parameters for the show certificates command.
                                 Variable  |
                                 Value  |
                                 ca <ca-label>  |
                                 Specifies the name of the certificate authority (CA). If you do not specify the name, the command displays the details of all configured CAs.  |
