Perform this procedure to enable SNMP traps when maximum number of IPv6 routes are reached.
Different hardware platforms support different parameter ranges. Use the CLI Help to see the available range.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip vrf vrfRED ipv6-max-routes-trap enable
Variable definitions
Use the data in the following table to use the ipv6-max-routes-trap command.
 Variable  |
 Value  |
 enable  |
 Enables SNMP trap generation based on the configured number of maximum IPv6 routes. The default is enabled.  |
