System logs are a valuable diagnostic tool. You can send log messages to flash files for later retrieval.
You can change log file parameters at anytime without restarting the system. Changes made to these parameters take effect immediately.
Configure logging to a flash file at all times as a best practice.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#boot config logfile 64 600 10
The following table defines parameters for the boot config command.
 Variable  |
 Value  |
 flags logging  |
 Enables or disables logging to a flash file. The log file is named using the format log.xxxxxxxx.sss. The first six characters after the prefix of the file name log contain the last three bytes of the chassis base MAC address. The next two characters specify the slot number. The last three characters denote the sequence number of the log file.  |
 logfile <64-500> <500-16384> <10-90>  |
 Configures the following logfile parameters:
