                                 Feature  |
                                 Product  |
                                 Release introduced  |
                                 Distributed Virtual Routing (DvR) Controller Important:
                            Because of a change in VOSS 6.0.1.2, the best practice is to use a minimum software version of 6.0.1.2 in DvR deployments.  |
                                 5420 Series  |
                                 Not Supported  |
                                 5520 Series  |
                                 VOSS 8.2.5  |
                                 VSP 4450 Series  |
                                 Not Supported  |
                                 VSP 4900 Series  |
                                 VOSS 8.1.5 VSP4900-12MXU-12XE, VSP4900-24S, and VSP4900-24XE only  |
                                 VSP 7200 Series  |
                                 VOSS 6.0.1  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 VOSS 6.0.1  |
                                 VSP 8400 Series  |
                                 VOSS 6.0.1  |
                                 VSP 8600 Series  |
                                 VSP 8600 8.0  |
                                 XA1400 Series  |
                                 Not Supported  |
                                 Distributed Virtual Routing (DvR) Leaf Important:
                                 5420 Series  |
                                 VOSS 8.4  |
                                 5520 Series  |
                                 VOSS 8.2.5  |
                                 VSP 4450 Series  |
                                 VOSS 6.1  |
                                 VSP 4900 Series  |
                                 VOSS 8.1  |
                                 VSP 7200 Series  |
                                 VOSS 6.0.1  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 VOSS 6.0.1  |
                                 VSP 8400 Series  |
                                 VOSS 6.0.1  |
                                 VSP 8600 Series  |
                                 Not supported  |
                                 XA1400 Series  |
                                 Not Supported  |
                                 Distributed Virtual Routing (DvR) dvr-one-ip  |
                                 5420 Series  |
                                 VOSS 8.4  |
                                 5520 Series  |
                                 VOSS 8.3  |
                                 VSP 4450 Series  |
                                 Not Supported  |
                                 VSP 4900 Series  |
                                 VOSS 8.3  |
                                 VSP 7200 Series  |
                                 VOSS 8.3  |
                                 VSP 7400 Series  |
                                 VOSS 8.3  |
                                 VSP 8200 Series  |
                                 VOSS 8.3  |
                                 VSP 8400 Series  |
                                 VOSS 8.3  |
                                 VSP 8600 Series  |
                                 VSP 8600 8.0  |
                                 XA1400 Series  |
                                 Not Supported  |
                                 Distributed Virtual Routing (DvR) In-band Management  |
                                 5420 Series  |
                                 VOSS 8.4  |
                                 5520 Series  |
                                 VOSS 8.2.5  |
                                 VSP 4450 Series  |
                                 VOSS 6.1  |
                                 VSP 4900 Series  |
                                 VOSS 8.1  |
                                 VSP 7200 Series  |
                                 VOSS 6.0.1  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 VOSS 6.0.1  |
                                 VSP 8400 Series  |
                                 VOSS 6.0.1  |
                                 VSP 8600 Series  |
                                 Not supported  |
                                 XA1400 Series  |
                                 Not Supported  |
