Configure the system log to track all user activity on the device. The system log can send messages of up to ten syslog hosts.
 - Click System Log.
 - In the System Log tab, select Enable.
 - Configure the maximum number of syslog hosts.
 - Configure the IP header type for the syslog packet.
 - Click Apply.
System Log Field Descriptions
Use the data in the following table to use the System Log tab.
 Name  |
 Description  |
 Enable  |
 Enables or disables the syslog feature. If you select this variable, this feature sends a message to a server on a network that is configured to receive and store diagnostic messages from this device. You can configure the type of messages sent. The default is enabled.  |
 MaxHosts  |
 Specifies the maximum number of remote hosts considered active and can receive messages from the syslog service. The range is 0–10 and the default is 5.  |
 OperState  |
 Specifies the operational state of the syslog service. The default is active.  |
 Header  |
 Specifies the IP header in syslog packets to circuitlessIP or default.
 The default value is default.  |
