Edit the chassis information to make changes to chassis-wide settings.
- In the Device Physical View tab, select the device.
 - Select Chassis.
 - Select the Chassis tab.
 - Edit the necessary options.
 - Select Apply.
Chassis Field Descriptions
Use the data in the following table to use the Chassis tab.
                                 Name  |
                                 Description  |
                                 Type  |
                                 Specifies the chassis type.  |
                                 ModelName This parameter does not apply on all platforms.  |
                                 Specifies the chassis model name.  |
                                 BrandName This parameter does not apply on all platforms.  |
                                 Specifies the chassis brand name.  |
                                 PartNumber  |
                                 Specifies the device part number.  |
                                 SerialNumber  |
                                 Specifies a unique chassis serial number.  |
                                 HardwareRevision  |
                                 Specifies the current hardware revision of the device chassis.  |
                                 NumSlots  |
                                 Specifies the number of slots available in the chassis.  |
                                 NumPorts  |
                                 Specifies the number of ports currently installed in the chassis.  |
                                 BaseMacAddr  |
                                 Specifies the starting point of the block of MAC addresses used by the switch for logical and physical interfaces.  |
                                 MacAddrCapacity  |
                                 Specifies the number of routable MAC addresses based on the BaseMacAddr.  |
                                 Temperature This parameter does not apply for all platforms.  |
                                 Specifies the temperature of the device measured in degrees Celsius.  |
                                 MacFlapLimitTime This parameter does not apply for all platforms.  |
                                 Configures the time limit for the loop-detect feature, in milliseconds, for MAC flapping. The value ranges from 10–5000. The default value is 500.  |
                                 AutoRecoverDelay  |
                                 Specifies the time interval, in seconds, after which auto-recovery runs on ports to clear actions taken by CP Limit or link flap. The default is 30.  |
                                 MTUSize  |
                                 Configures the maximum transmission unit size. The default varies depending on the platform:
                                 MgidUsageVlanCurrent  |
                                 Number of MGIDs for VLANs currently in use.  |
                                 MgidUsageVlanRemaining  |
                                 Number of remaining MGIDs for VLANs.  |
                                 MgidUsageMulticastCurrent  |
                                 Number of MGIDs for multicast currently in use.  |
                                 MgidUsageMulticastRemaining  |
                                 Number of remaining MGIDs for multicast.  |
                                 DdmMonitor  |
                                 Enables or disables the monitoring of the DDM. When enabled, the user gets the internal performance condition (temperature, voltage, bias, Tx power and Rx power) of the SFP/XFP. The default is disable.  |
                                 DdmMonitorInterval  |
                                 Configures the DDM monitor interval in the range of 5 to 60 in seconds. If any alarm occurs, the user gets the log message before the specific interval configured by the user. The default value is 5 seconds.  |
                                 DdmTrapSend  |
                                 Enables or disables the sending of trap messages. When enabled, the trap message is sent to the Device manager, any time the alarm occurs. The default is enable.  |
                                 DdmAlarmPortdown  |
                                 Sets the port down when an alarm occurs. When enabled, the port goes down when any alarm occurs. The default is disable.  |
                                 PowerUsage This parameter does not apply on all platforms.  |
                                 Specifies the amount of power the CPU uses.  |
                                 PowerAvailable This parameter does not apply on all platforms.  |
                                 Specifies the amount of power available to the CPU.  |
