BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
 - Select BFD.
 - Select the Performance counters tab.
BFDPerformance Counters Field Descriptions
Use the data in the following table to use the Performance counters tab.
| Name | Description |
                                 PktIn  |
                                 Specifies the total number of BFD messages received for this BFD session.  |
                                 PktOut  |
                                 Specifies the total number of BFD messages sent for this BFD session.  |
