The following table describes the secure and nonsecure protocols that the switch supports.
 Nonsecure protocols  |
 Default status  |
 Equivalent secure protocols  |
 Default status  |
 FTP and Trivial FTP  |
 Disabled  |
 Secure Copy (SCP) and Secure File Transfer Protocol (SFTP)  |
 Disabled  |
                                 Note:
File Transfer Protocol (FTP) and Trivial File Transfer Protocol (TFTP) support both IPv4 and IPv6 addresses, with no difference in functionality or configuration.  |
 Telnet  |
 Disabled  |
 Secure Shell version 2 (SSHv2)  |
 Disabled  |
 SNMPv1, SNMPv2  |
 Enabled  |
 SNMPv3  |
 Enabled  |
 rlogin Note:
Exception: only supported only on VSP 8600 Series.  |
 Disabled  |
 SSHv2  |
 Disabled  |
 HTTP  |
 Disabled  |
 HTTPS Important:
Take the appropriate security precautions within the network if you use HTTP. You must use the web-server enable command in CLI before you can access EDM.  |
 Enabled  |
