This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB layer 2 multicast I-SID list redistribution for the home area.
 - Select MultiArea.
 - Select the L2 MC Redist Home ISID List tab.
 - Select Insert.
 - In the ISID List Name field, type the name of the I-SID list.
 - Select Enable.
 - Optional: In the PolicyName field, type the policy name.
 - Select Insert.
L2 MC Redist Home ISID List Field Descriptions
Use the data in the following table to use the L2 MC Redist Home ISID List tab.
| Name | Description |
                                 ISID List Name  |
                                 Specifies the name of the I-SID list.  |
                                 Enable  |
                                 Enables Multi-area SPB layer 2 multicast redistribution for the specific I-SID list in the home area.  |
                                 PolicyName  |
                                 Specifies the name of the redistribution policy.  |
