Perform the following procedure to configure the number of disks to be used by the virtual service configured on the switch.
 - Click Virtual Service.
 - Click the Disks tab.
 - Click Insert.
 - In the ServName field, enter the virtual service name.
 - In the Name field, enter the disk name.
 - Optional: In the Size field, enter a value.
 - Click Insert.
Disks Field Descriptions
Use data in the following table to use the Disks tab.
                         Name  |
                         Description  |
                         ServName  |
                         Specifies the virtual service name. Note:
                    The specified name must match the virtual service name configured on the switch.  |
                         Name  |
                         Specifies the name of the disk used by the virtual service.  |
                         Size  |
                         Specifies the disk size (in Gigabytes). The default is 10 Gigabytes.  |
                         SizeAllot  |
                         Shows the disk size (in Megabytes) allocated to the virtual service.  |
                         SizeAvailable  |
                         Shows the available disk storage space (in Megabytes).  |
                         SizeUsed  |
                         Shows the amount of disk storage space (in Megabytes) used by the virtual service.  |
