By default, both sides of an IPsec connection are Initiator devices. IPsec Network Address Translation Traversal (NAT-T) connections require that one side of the connection is a Responder device and the other side of the connection is an Initiator device.
If the Responder device and the Initiator device are both behind NAT, the IPsec NAT-T Initiator device requires the public IP address of the Responder device.
Perform the following steps to configure one side of an IPsec NAT-T connection as a Responder device:
- Select IS-IS.
- Select Logical Interfaces.
- Select Insert.
- Select IpsecNatConfigResponderOnly.
If required, perform the following steps on the IPsec NAT-T Initiator device to configure the public IP address of the Responder device:
- Select IS-IS.
- Select Insert.
- For IpsecNatConfigRemoteNatIPAddr, enter the public IP address of the Responder device.
Use the data in the following table to use the Logical Interfaces tab and the Insert Logical Interfaces dialog. The available fields in the dialog differ depending on the type of core you select: layer 2 or ip.
Name |
Description |
Id |
Specifies the index number that uniquely identifies this logical interface. This field displays on the Insert Logical Interfaces dialog only. |
IfIndex |
Specifies the index number that uniquely identifies this logical interface. This field is read-only. This field displays on the Logical Interfaces tab only. |
Name |
Specifies the administratively assigned name of this logical interface, which can be up to 64 characters. |
Type Note:
Exception: Type Layer 2 is not supported on XA1400 Series. |
Specifies the type of logical interface to create:
DestIPAddr |
Specifies the destination IP address for the IP-type logical interface. |
DestIfIndex Note:
Exception: Not supported on XA1400 Series. |
Specifies the physical port or MultiLink Trunking (MLT) that the Layer 2 logical interface is connected to. |
Vids Note:
Specifies the list of VLANs that are associated with this logical interface. |
PrimaryVid Note:
Specifies the primary tunnel VLAN ID associated with this Layer 2 Intermediate-System-to-Intermediate-System (IS-IS) logical interface. |
CircIndex |
Identifies the IS-IS circuit created under the logical interface. This field displays on the Logical Interfaces tab only. |
NextHopVrf Note:
Identifies the next-hop VRF name to reach the logical tunnel destination IP. This field displays on the Logical Interfaces tab only. |
IpsecEnable Note:
Exception: Only supported on XA1400 Series. |
Specifies whether the logical interface should use IPsec. |
AuthenticationKey Note:
Specifies the authentication key of this logical interface, which can be up to 32 characters. |
ShapingRate Note:
Specifies the value, in Mbps, of the Egress Tunnel Shaper applied to the logical interface. |
Mtu Note:
Specifies the Maximum Transmission Unit (MTU) size for each logical interface. The default MTU value is 1950. |
IpsecTunnelDestAddress Note:
Specifies the destination IP address for the IPsec tunnel. |
| BfdEnable Note: Exception: Not
supported on VSP 8600
Series or XA1400
Series.
Enables or disables BFD on an IS-IS Logical Interface. |
IpsecResponderOnly Note:
Specifies whether the device is a Responder device in an IPsec Network Address Translation Traversal (NAT-T) connection. |
| IpsecRemoteNatIPAddr Note:
Specifies the public IP address of the NAT router connected to the Responder device in an IPsec NAT-T connection. |
IpsecAuthMethod Note:
Configures the IPsec authentication method for the tunnel as either a pre-shared key or RSA signature for digital certificates. The default is pre-shared key. |
Compression Note:
Reduces the size of the IP datagram to improve the communication performance between hosts connected behind Backbone Edge Bridges (BEB). Tip:
As a best practice, use IPsec compression only for Fabric Extend tunnels where latency is greater than 70ms. |
FragmentBeforeEncrypt Note:
Enables or disables the fragmentation of packets before IPsec encryption on the tunnel. By default, fragmentation before encryption is disabled. |
TunnelSourceType Note:
Specifies the type of source IP address for the IPsec tunnel.
The default is global. |
TunnelSourceAddress Note:
Specifies the source IP address for the IPsec tunnel. |
TunnelVrf Note:
Specifies the VRF name associated with the IPsec tunnel. |
Esp Note:
Specifies the Encapsulating Security Payload (ESP) cipher suite for IPsec.
The default value is aes128gcm16-sha256. |
