Perform this procedure to enable Virtual Link Aggregation Control Protocol (VLACP) on an Extreme Integrated Application Hosting (IAH) port. VLACP periodically checks the end-to-end health of a point-to-point connection.
 - Select the IAH port you want to configure.
 - Select the VLACP tab.
 - Select AdminEnable.
 - Configure the other parameters as required.
 - Click Apply.
VLACP Field Descriptions
Use data in the following table to configure the VLACP tab.
                         Name  |
                         Description  |
                         AdminEnable  |
                         Enables VLACP on the Extreme Integrated Application Hosting (IAH) port. The default is disabled.  |
                         OperEnable  |
                         Specifies the VLACP operational status for the IAH port. The default is false.  |
                         FastPeriodicTimer  |
                         Specifies the number of milliseconds between periodic transmissions using short timeouts. Set the same value for all LACP enabled IAH ports. The default value is 200.  |
                         SlowPeriodicTimer  |
                         Specifies the number of milliseconds between periodic transmissions using long timeouts. Set the same value for all LACP enabled IAH ports. The default value is 30000.  |
                         Timeout  |
                         Specifies the timeout control value. The default value is long.  |
                         TimeoutScale  |
                         Specifies the value used to calculate timeout duration from the periodic time for all VLACP enabled IAH ports. Timeout = PeriodicTime x TimeoutScale. The default value is 3.  |
                         EtherType  |
                         Specifies the VLACP protocol identification. The ID is in hexadecimal format. The default value is 0x8103.  |
                         EtherMacAddress  |
                         Specifies the multicast MAC address exclusively used for VLACPDUs.  |
                         PortState  |
                         Specifies the VLACP port state.  |
