 - Select Chassis.
 - Select the MACSec MKA Profile tab.
 - Select Insert.
 - For Id, type an MKA ID value.
 - For Name, type the profile name.
 - Optional: Select ReplayProtectEnable to enable replay protect.
 - Optional: For ReplayProtectWindow, type a value for the replay protect window size.
 - Optional: From the OffsetValue options, select a level for confidentiality offset.
 - Select Insert.
MACSec MKA Profile Field Descriptions
Use the data in the following table to use the MACSec MKA Profile tab.
                                 Name  |
                                 Description  |
                                 Id  |
                                 Specifies a unique identification number for an MKA profile.  |
                                 Name  |
                                 Specifies the profile name.  |
                                 ReplayProtectEnable  |
                                 Specifies whether replay protect is enabled. The default is disabled.  |
                                 ReplayProtectWindow  |
                                 Specifies the maximum acceptable difference in packet ID numbers between out of order packets. If a packet ID number differs from the ID number of the previously received packet by more than the specified window size, it is dropped.  |
                                 OffsetValue  |
                                 Specifies the number of bytes after the Ethernet header from which data encryption begins. The default is no offset.  |
                                 PortMembers  |
                                 Specifies the ports that are members of an MKA profile.  |
