The following table defines parameters for the link-debounce command.
Variable |
Value |
<0-300000> |
Link debounce configures time for ports in milliseconds. The default status is disabled for all ports when not initially configured. If you run default link-debounce command, the default configuration is enabled with a value of 1,000 milliseconds. To return to the initial disabled state, you must run no link-debounce command or set the Link Debounce timer to 0. |
