Perform the following procedure to configure emergency call service location of local LLDP-MED on specific ports.
Configuring emergency call service location on port 2/1–2/10:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 2/1–2/10 Switch:1(config-if)#lldp location-identification ecs-elin 123456789
The following table defines parameters for the lldp location-identification ecs-elin command.
 Variable  |
 Value  |
 WORD<10–25>  |
 Specifies the emergency line information number for emergency call service.  |
