After you have configured the SPBM infrastructure, you can enable SPBM Layer 3
                        Virtual Services Network (VSN) to advertise IPv4 routes across the SPBM
                        network from one VRF to another using the following procedure.
                SPBM Layer 3 VSN uses IS-IS to exchange the routing information for each VRF. In
                        the VRF, just like in the Global Router (VRF 0), the routes are not
                        redistributed into IS-IS automatically. To advertise the VRF routes, you
                        must explicitly redistribute one of the following protocols into IS-IS:
                        direct, static, RIP, OSPF, or BGP. Routing between VRFs is also possible by
                        using redistribution policies and injecting routes from the other protocols.
You must configure the required SPBM IS-IS
                                                  infrastructure.
You must configure a VRF and IP VPN instance on
                                                  the switch. For more information about how to
                                                  configure a VRF, see VRF Lite configuration using Enterprise Device Manager.
You must create the Customer VLANs and add
                                                  slots/ports.
                                In the
                                        navigation pane, expand .
                                Select
                                                IP-VPN.
                                Select the
                                                VPN tab.
                                To create an IP
                                        VPN instance, select Insert.
                                Select the
                                        ellipsis button (...), select a VRF to associate with
                                        the IP VPN, and click Ok.
                                Select
                                                Insert.
                                In the
                                                Enable column, select enable to enable the IP VPN on the
                                        VRF.
                                In the
                                                IsidNumber column, specify an I-SID to
                                        associate with the VPN.
                                Select
                                                Apply.
                                In the
                                Select
                                                Policy.
                                To identify
                                        routes on the local switch to be announced into the SPBM
                                        network, select the Route
                                                Redistribution tab.
                                Select
                                                Insert.
                                In the
                                                DstVrfId box, select the ellipsis
                                                (...), and then select the destination
                                        VRF ID and select Ok.
                                In the
                                                Protocol box, select isis as the route destination.
                                In the
                                                SrcVrfId box, select (...) button, select the source VRF ID
                                        and click Ok.
                                In the
                                                RouteSource box, select the source
                                        protocol.
                                In the
                                                Enable box, select enable.
                                In the
                                                RoutePolicy box, select the ellipsis
                                                (...), choose the route policy to apply
                                        to the redistributed routes and select Ok.
                                Configure the
                                        other parameters as required.
                                Select
                                                Insert.
                                To apply the
                                        redistribution configuration, select the Applying Policy tab.
                                Select
                                                RedistributeApply, and then select
                                                Apply.
