This procedure only applies to VSP 8600 Series.
Specify the primary CPU to designate which CPU becomes the primary after the switch performs a full power cycle. This procedure applies only to hardware with two CPUs.
Configure the standby delay to set the number of seconds a standby CPU waits before trying to become the primary CPU. The standby delay applies when two CP modules boot at the same time. The designated standby CP waits for the configured number of seconds before attempting to assert itself as the primary. Only one CP can be the primary in a chassis.
Caution
If you configure the standby delay to too short a value, the configured standby CP can become a primary. If you configure the standby delay to too long, it can delay the standby CP asserting itself and continue booting when the designated CP is inserted, but fails booting.
Switch:1>enable Switch:1#configure terminal
Specify the slot number, either 1 or 2, for the primary CPU:
Switch:1(config)# boot config master 2 Switch:1(config)# save config
Specify the number of seconds a standby CPU waits before trying to become the primary CPU:
Switch:1(config)# boot config delay 30 Switch:1(config)# save config Switch:1(config)# reset
The following table defines parameters for the boot config master command.
| Variable | Value |
                                 <1–2>  |
                                 Specifies the slot number, either 1 or 2, for the primary CPU. The default value is slot 1.  |
