Use the following procedure to display information about all MKA profiles configured on the switch. Optionally, you can view information about a specific MKA profile.
This procedure only applies to VSP 8400 Series.
The following example displays MACsec MKA profile information:
Switch:1#show macsec mka profile
                               MACsec MKA Profile
Profile         Profile    Cipher       Confidentiality   Replay     Window      Port
Name            Id         Suite           Offset         Protect     Size
test030519      1        gcm-aes-128          30           Enabled      200    1/3
test031519      2        gcm-aes-128          50           Enabled      225    1/4
test032019      3        gcm-aes-128          30           Enabled      240    2/2
All 3 out of 3 Total Num of MACsec MKA Profiles displayed
            The following example displays MACsec MKA information for a specific profile.
Switch:1#show macsec mka profile test030519
                               MACsec MKA Profile
The following table defines parameters for the show macsec mka profile command.
| Variable | Value |
                             WORD<1-16>  |
                             Specifies the MKA profile name. An MKA profile name can consist only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive.  |
