Use this procedure to modify the assigned name for the Service Identifier (I-SID).
Product Notice: For XA1400 Series, you can modify a service name for IPv4 static routes and IPv4 loopback CLIP interfaces only. For information about feature support, see VOSS Feature Support Matrix.
This procedure is not supported on VSP 8600 Series.Procedure
 - Select ISID.
 - Select Global Name.
 - View the name of the I-SID in the ISID Name field. To modify, double-click the name of the I-SID and type a new name.
 - Select Apply.
Global Name Field Descriptions
Use the data in the following table to use the Global Name tab.
                                 Name  |
                                 Description  |
                                 ISID Id  |
                                 Specifies the index number that uniquely identifies the I-SID.  |
                                 ISID Name  |
                                 Specifies the name of the I-SID, which can be up to 64 characters. This field is not supported on all hardware platforms.  |
| UsedByType |
                                 Specifies the I-SIDs that are in use as services. An I-SID can have one base type or a combination of base types so that multiple services can use the same I-SID at the same time.  |
