Use this procedure to insert a FA Zero Touch Client.
                In the navigation pane, expand
 - Click Fabric Attach.
 - Click the Zero Touch Client Auto Attach tab.
 - Click Insert.
The Insert Zero Touch
                            Client dialog box opens.
 - In the Type field click the ellipsis
and select a client. Click Ok to select the
client or Refresh to update the list.
                In the Isid field enter
                    the I-SID value.
                    The I-SID value is between 0 and 16777214.
             - Click Insert.
