Configure local port Auto-Negotiation advertisements to specify the speed and duplex mode for traffic between local ports and remote link partners. Supported speeds and duplex modes vary, depending on your hardware.
You must enable Auto-Negotiation before you perform this procedure.
Configure local port Auto-Negotiation advertisements.
The following table defines parameters for the auto-negotiation-advertisements command.
                                 Variable  |
                                 Value  |
                                 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                                 Specifies the port or ports that you want to configure.  |
                                 10000-full  |
                                 Advertises 10000 Mbps full duplex.  |
                                 5000-full  |
                                 Advertises 5000 Mbps full duplex.  |
                                 2500-full  |
                                 Advertises 2500 Mbps full duplex.  |
                                 1000-full  |
                                 Advertises 1000 Mbps full duplex.  |
                                 100-full  |
                                 100-half  |
                                 Advertises 10000 Mbps half duplex.  |
                                 10-full  |
                                 Advertises 10 Mbps full duplex.  |
                                 10-half  |
                                 Advertises 10 Mbps half duplex.  |
                                 none  |
                            Configures the Auto-Negotiate value to none. |
