View ACE Statistics
View ACE statistics to ensure that the filter operates correctly.
The ACL statistics do not support security action on some hardware platforms.
View ACE statistics:
Based on your hardware platform, the output may display all the ACL packets or segregate them as QoS and security ACL packets.
Switch:1>enable
Switch:1#show filter acl statistics all
                          Acl Global Statistics Table
Acl Id  Acl Name    Acl Type  Acl Sec    Acl Sec    Acl QOS    Acl QOS
                              Packets    Bytes      Packets    Bytes
1       ACL-1       inVlan    0          0          0          0
2       ACL-2       inVlan    0          0          0          0
Displayed 2 of 2 entries
                          Acl Default Statistics Table
--More-- (q = quit)
Switch:1#show filter acl statistics default
Switch:1#show filter acl statistics global 2
Displayed 1 of 1 entries
Use the data in the following table to use the show filter acl statistics command.
 Variable  |
 Value  |
 <acl-id>  |
 Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
 <ace-id>  |
 Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.  |
