Perform the following procedure to create or configure an OSPF accept policy.
- In the navigation pane, expand: .
 - Select Policy.
 - Select the OSPF Accept tab.
 - Select Insert.
 - Configure the parameters as required.
 - Select Insert.
OSPF Accept field descriptions
Use the data in the following table to use the OSPF Accept tab.
Name  | Description  |
AdvertisingRtr  | Specifies the routing ID of the advertising router.  |
Enable  | Enables or disables the advertising router. You can also enable or disable advertising in the OSPF Accept tab of the Policy dialog box by clicking in the field and selecting enable or disable from the menu. The default is disable.  |
MetricType  | Specifies the OSPF external type. This parameter describes which types of OSPF ASE routes match this entry.
 You can also select your entry in the OSPF Accept tab of the Policy dialog box by clicking in the field and selecting any, type1, or type2 from the menu. The default is any.  |
PolicyName  | Specifies the name of the OSPF in filter policy. Click the ellipsis button and choose from the list in the Policy Name dialog box. To clear an entry, use the ALT key.  |
