Configure inbound filtering on a RIP interface to determine whether to learn a route on a specified interface and to specify the parameters of the route when it is added to the routing table. Configure outbound filtering on a RIP interface to determine whether to advertise a route from the routing table on a specified interface and to specify the parameters of the advertisement.
The port on which the multimedia filter is enabled becomes a DIFFSERV access port.
- In the navigation pane, expand the following folders: .
 - Click Policy.
 - Click the RIP In/Out Policy tab.
 - In the desired row, double-click the InPolicy or OutPolicy column.
 - Select a preconfigured In/Out policy and click OK.
RIP In/Out Policy field descriptions
Use the data in the following table to use the RIP In/Out Policy tab.
Name  | Description  |
Address  | Specifies the IP address of the RIP interface.  |
Interface  | Specifies the internal index of the RIP interface.  |
InPolicy  | Specifies the policy name used for inbound filtering on this RIP interface. This policy determines whether to learn a route on this interface and specifies the parameters of the route when it is added to the routing table.  |
OutPolicy  | Specifies the policy name used for outbound filtering on this RIP interface. This policy determines whether to advertise a route from the routing table on this interface and specifies the parameters of the advertisement.  |
