Configure community lists to specify permitted routes by using their BGP community. This list acts as a filter that matches communities or AS numbers.
Change the VRF instance as required to configure BGP on a specific VRF instance. The VRF must have an RP trigger of BGP. Not all parameters are configurable on non-default VRFs.
 - Click Policy.
 - Click the Community List tab.
 - Click Insert.
 - Configure the list as required.
 - Click Insert.
Community List field descriptions
Use the data in the following table to use the Community List tab.
 Name  |
 Description  |
 Id  |
 Specifies the community list. The range is 0–1024.  |
 MemberId  |
 Specifies the community list member ID. The range is 0–65535.  |
 Mode  |
 Specifies the action to take if the system selects a policy for a specific route. Select permit (allow the route) or deny (ignore the route).  |
 Community  |
 Specifies the community access list community string.  |
