Configure an AS path list to restrict the routing information a router learns or advertises to and from a neighbor. The AS path list acts as a filter that matches AS paths.
Change the VRF instance as required to configure BGP on a specific VRF instance. The VRF must have an RP trigger of BGP. Not all parameters are configurable on non-default VRFs.
 - Click Policy.
 - Click the As Path List tab.
 - Click Insert.
 - Enter the appropriate information for your configuration.
 - Click Insert.
As Path List field descriptions
Use the data in the following table to use the As Path List tab.
 Name  |
 Description  |
 Id  |
 Specifies the AS path list.  |
 MemberId  |
 Specifies the AS path access list member ID.  |
 Mode  |
 Specifies the action to take if the system selects a policy for a specific route. Select permit (allow the route) or deny (ignore the route).  |
 AsRegularExpression  |
 Specifies the expression to use for the AS path.  |
