Configure an ACE to filter IPv4 routed packets.
This procedure does not apply to VSP 8600 Series or XA1400 Series.
The ACL exists.
The ACE exists.
 - Select Advanced Filters (ACE/ACLs).
 - Select IpRouted tab.
 - Select Insert.
 - In the AclId field, type the appropriate ACL ID.
 - In the AceId field, type the appropriate ACE ID.
 - RoutedOnly
 - Select Insert.
IpRouted Field Descriptions
The following table describes values on the IpRouted tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID. Value range of 1 to 2048.  |
                                 AceId  |
                                 Specifies the ACE ID. Value range of 1 to 2000.  |
