Configure an ACE to filter IPv6 routed packets only.
This procedure does not apply to VSP 8600 Series or XA1400 Series.
The ACL exists.
The ACE exists.
 - Select Advanced Filters (ACE/ACLs).
 - Select the Ipv6Routed tab.
 - Select Insert.
 - In the AclId field, type the appropriate ACL ID.
 - In the AceId field, type the appropriate ACE ID.
 - Select RoutedOnly.
 - Select Insert.
Ipv6Routed Field Descriptions
The following table describes values on the Ipv6Routed tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
                                 AceId  |
                                 Specifies the ACE ID.  |
                                 RoutedOnly  |
                                 Specifies the match for IPv6 routed packets only.  |
