Create a community to use in forming a relationship between an SNMP agent and one or more SNMP managers. You require SNMP community strings for access to the switch using an SNMP-based management software.
 - Click Community Table.
 - Click Insert.
 - In the Index box, type an index.
 - In the Name box, type a name that is a community string.
 - In the SecurityName box, type a security name.
 - In the ContextName box, type the context name.
 - Click Insert.
Community Table field descriptions
Use the data in the following table to use the Community Table tab.
 Name  |
 Description  |
 Index  |
 Specifies the unique index value of a row in this table. The range is 1–32 characters.  |
 Name  |
 Specifies the community string for which a row in this table represents a configuration.  |
 SecurityName  |
 Specifies the security name in the VACM group member table to which the community string is mapped. The range is 1–32 characters.  |
 ContextEngineID  |
 Indicates the location of the context in which management information is accessed when using the community string specified in Name.  |
 ContextName  |
 Specifies the context in which management information is accessed when you use the specified community string.  |
