View contexts to see the contents of the context table in the View-based Access Control Model (VACM). This table provides information to SNMP command generator applications so that they can properly configure the VACM access table to control access to all contexts at the SNMP entity.
 - Click VACM Table.
 - In the VACM Table tab, click the Contexts tab.
Contexts field descriptions
Use the data in the following table to use the Contexts tab.
 Variable  |
 Value  |
 ContextName  |
 Shows the name identifying a particular context at a particular SNMP entity. The empty contextName (zero length) represents the default context.  |
