Delete a RIP In/Out policy when you no longer want to learn a route
on a specified interface or advertise a route from the routing table
on a specified interface.
- In the navigation pane,
expand the following folders: .
 - Click Policy.
 - Click the RIP In/Out Policy tab.
 - In the desired row,
double-click the InPolicy or OutPolicy column for the policy you want to delete.
 - In the InPolicy or OutPolicy dialog box, press CTRL and
then, click the policy you want to delete.
 - Click OK.
The policy is deleted and you are returned to the RIP In/Out Policy
tab.
 - Click Apply.
