Use the following procedure to enable IPsec on an IPv6 interface.
                                In the
                                        navigation pane, expand .
                                Select
                                                IPSec.
                                Select the
                                                IPv6
                                                Interfaces tab.
 - In the IpsecEnable column, double-click in the IpsecEnable field, and select enable from the drop-down box.
                                Select
                                                Apply.
